Tire size question
89lxsport50
550
Franklin Tennessee
I'm looking at buying a set of Nitto 555's for my 02 GT. The wheels are the stock Bullitts, and I'm running 373 gears. I want to step up from the stock 245 width to 255. I'm leaning towards 255/45/17 because I think the 255/40/17 would look too short. My question is, will the difference in tire diameter and revolutions per mile affect the performance of the car? I want to get the most out of the 373s I can. How much will my speedometer be off?
Here are the specs on the tires:
245/45/17 - 25.67 in. - 821 revs per mile
255/40/17 - 25.08 in. - 829 revs per mile
255/45/17 - 25.95 in. - 800 revs per mile
I'm running the 255/40-17 and I don't like the shorter height. I'd go with the taller tire (255/45-17) just for the better looks.
Will you notice difference in performance? No, not anything recognizable. As per this calculator, going from a 245/45-17 to a 255/40-17 with 3.73s will result in a 3.83:1 equivalent gear ratio. Going from 245/45-17 to a 255/45-17 will result in a 3.68:1 equivalent gear ratio.
The speedo with my tires is off just a bit. When it shows 80, I'm actually doing about 76.
Well, I went ahead and got the 255/45/17s. They look great, and fill in the wheel well better than the stock 245/45s. They are quite a bit softer/cushier feeling than the BFGs I had before. I may play around with the air pressure a little to see if I can firm them up a little. They sure do grip well on dry pavement. I haven't tried them in the rain yet.
