- Dec 1, 2003
- 267
- 0
- 0
Tire bulge???c2see21 said:yeah they will fitbut you are opening up a can of worms here. there are going to be people arguing about whether it's safe or not, & whether it looks good or not
i personally wouldn't do it cause the rear end feels too "loose" to me in corners. but other people on here say its just fine. oh, and you will get tire bulge unless your running a 9" rim
That IMO isn't that great. If you want to go bigger there are aftermarket wheels that look factory but offer the larger rim size. That would be the way to go.wht99gtconv said:Tire bulge???
315's won't fit will itGoBabyVroommm said:I would go no bigger then 255 in the front and 315 in the back. I like the way it looks personally.
Did you at least get a little better traction with them on factory wheels.dragginuts said:I did it for a little over six months til i got my 10th anniversary wheels. Will it fit, yes...was it the best handling car, no...but it worked for me. You arent getting the full advantage of the tire on your factory wheels, but if you are planning on upgrading wheels later, but you need tires now, then yes go ahead and put them on your stockers.
wht99gtconv said:Did you at least get a little better traction with them on factory wheels.
new22003 said:This has been argued over a lot. It seems according to some people it works great. According to tire manufacturers you shouldnt do it. Its your choice and depends on if you are going for looks or performance. A good thing to do is go to a tire site and see what size rim they reccomend for each tire. Here is a link to the BFG drag radial wheel to tire size chart.
http://www.tirerack.com/tires/Spec.jsp?make=BFGoodrich&model=Comp+T/A+Drag+Radial
For a 275/40/17 bfg drag radial the reccomend a 9-11 inch rim. The tires section width is 11 inches (distance between sidewalls). Tread width is 10.2 inches(contact patch).
