Tires
  • Thread starter Thread starter 1986foxbody
  • Start date Start date Oct 23, 2011
1 of 2 Next Last
1986foxbody
Menifee, California
Oct 23, 2011
  • Oct 23, 2011
Will a 275 40 17 fit on the front of a 1986 mustang. I plan on lowering it a little. not sure if I need a flared fender or not. Any one done this? I want to run same size on all four corners
jdwyer25
116
Cameron, NC
Oct 23, 2011
  • Oct 23, 2011
Yeah it should fit as long as your not running coil overs. I tried to put that same size on my fox, but due to coil overs I wasn't able to use that size of tire.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Oct 23, 2011
  • Oct 23, 2011
That's freakin' huge for the front. One thing you are probably going to run into with a tire that size is "tramlining". It will want to follow every rut on the freeway.
1986foxbody
Menifee, California
Oct 24, 2011
  • Oct 24, 2011
I will be running coil overs. there has got to be a way to make them fit. I have heard of it being done. I just need to find out how they did it with coil overs
thanks for the reply
1986foxbody
Menifee, California
Oct 24, 2011
  • Oct 24, 2011
Wouldn't the tramlining depend on the type of treat on the tire?
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Oct 24, 2011
  • Oct 24, 2011
My lightning did that. Wasnt terrible and on a car that isnt daily driven i dont think its much of a issue. I DD'd my lightning too btw, 20 miles a day on the highway, it wasnt that bad.
Here is what you should do, flared fenders are ugly.
http://www.stangnet.com/mustang-forums/7917801-post37.html
1986foxbody
Menifee, California
Oct 24, 2011
  • Oct 24, 2011
What exactly did they do in those pics?
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Oct 24, 2011
  • Oct 24, 2011
1986foxbody said:
Wouldn't the tramlining depend on the type of tread on the tire?
Not in my experience. I've experienced it with two different 'Stangs when I've gone to wider tires on the front. Both had to have the problem corrected by adding caster to the alignment using caster/camber plates. It's not a big deal, you should just be aware that it may be an issue when you're done.
A Lightning is a completely different animal than a Mustang with a totally different steering system. Apples and bananas.
ID89GT
1,659
18
49
Spokane Valley, WA
Oct 24, 2011
  • Oct 24, 2011
Why so wide up front?
1986foxbody
Menifee, California
Oct 24, 2011
#10
  • Oct 24, 2011
  • #10
I want to run that size on the rear and I want to keep all four tires the same size. and I think it looks good.
ID89GT
1,659
18
49
Spokane Valley, WA
Oct 24, 2011
#11
  • Oct 24, 2011
  • #11
That thing is gonna rub like crazy
stykthyn
5,232
2,652
223
gainesville
Oct 24, 2011
#12
  • Oct 24, 2011
  • #12
I run that on the front of my 87. It fits but I am running struts at stock height.
1986foxbody
Menifee, California
Oct 24, 2011
#13
  • Oct 24, 2011
  • #13
do you have any pics?
stykthyn
5,232
2,652
223
gainesville
Oct 25, 2011
#14
  • Oct 25, 2011
  • #14
I would really advise against it. Far from ideal and rubs even with rack limiters and rolled fenders.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Oct 25, 2011
#15
  • Oct 25, 2011
  • #15
My 91 notch had fox LCA's, 95 spindles and 17x8 245's up front and they rubbed on the K-frame during a full lock.
My 81 notch had fox LCA's, 96-04 spindles and 17x8's with a 245 and they did not rub anything during a full lock.
My 91 GT had fox LCA's 96-04 spindles and 17x9's with 255's and the rim (not the tire) the rim rubb on the K-frame during a full turn. Crazy.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Oct 26, 2011
#16
  • Oct 26, 2011
  • #16
With forward offset control arms, coil overs and a 24mm offset rims 275/40/17's will fit great up front. slight rubbing but not a whole lot. I never experienced tramlining, but it didnt get highway'ed a whole lot
stykthyn
5,232
2,652
223
gainesville
Oct 26, 2011
#17
  • Oct 26, 2011
  • #17
unless you plan on banking the car through NASCAR style turns or taking corners like the batmobile there is no reason to run a front tire that size.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Oct 26, 2011
#18
  • Oct 26, 2011
  • #18
Having the same size tire all the way around is nice. If he's going to run coil overs he just may want to burn some turns.
When i added the k-member though that when all the fender mods had to happen
stykthyn
5,232
2,652
223
gainesville
Oct 26, 2011
#19
  • Oct 26, 2011
  • #19
I agree that having all the same size tires is nice, but that is a hella huge tire to stuff under the front and unless you are running the forward offset K and control arms its going to be a PITA to keep those things from tearing themselves apart underneath the fenders. I just purchased a set of 245/45/17 to replace the tires I have up there now. If the 275s would comfortably stretch over the 10.5" wheel in the back I would rotate them back to there and sell off the 315's.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Oct 26, 2011
#20
  • Oct 26, 2011
  • #20
Not forward offset k-member, just the control arms with a stock k-member. That setup they didnt even hang out, but i did have to remove the fender liner.
This car got **** canned a long time ago, but it had the forward offset arms, 95 spindles and bilstein coil overs and they fit great. Like it was meant to be there, rim rubbed a bit on the control arm but nothing bad, and didnt even touch the inner sheet metal at all.
1 of 2 Next Last
M
Rim suggestions
  • mason5.0
  • Sep 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
H
Best tire size for 91 Fox 18x9 wheels. On coilovers
  • hassler
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
KRUISR
305-45-17 tires on Pony wheels (17")?
  • TTSaleen
  • Mar 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 25, 2026
TTSaleen
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Wheel backspacing
  • Brad Hanks
  • Sep 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2025
Brad Hanks
