Got a fox body with an original Tremec TKO (3650), ford racing driveshaft, and a factory yoke from a newer model mustang (T45).
I have the driveshaft off now and I noticed the yoke is twisted (I have a little over 500hp). I am trying to find a Chromoly / hardened yoke + U joint for this but one does not seem to exist.
What is strange is the 31 spline ford racing yoke fits the T45, C6, and the 3550, but the strange engineering yoke only fits the T45 and C6. I know this because I bought it thinking it was exactly the same as the ford one but it didn't fit. Apparently the splines are cut differently, and the ford one gives just enough room to fit all of the above.
Ford Racing M-4841-A - Ford Racing Transmission Yokes - Overview - SummitRacing.com
Think this one will be stronger than the OEM Ford one and will handle 500hp?
Strange Engineering U1669 - Strange Super Duty Transmission Yokes - Overview - SummitRacing.com
Here is the strange eng one. As you can see, all specs are the same, but it doesn't fit
I even got the U joint conversion to go from 1330 to 1350... I thought I was all set.
