TKO Guru needed
whtnotch
123
Chicago
O.k I'm now on my second (2nd!) TKO 600.The first one leaked like a siv and was told there was some manufacture issues internally or (the Spec clutch I was using) once they received the trans back.I waited 4 months for the new one if anyone remembers the ***** i went thru on earlier posts.Anyway,I was told to buy A Ram clutch(lil less agressive?) to replace the Spec stage 1 I had in it to begin with. I went to Sutton High Performance in Matteson IL(my home performance shop(very helpfull people)they said they never heard of a Spec clutch being a bad clutch. They said Spec is a very repritable company(just as I thought). I ended up ordering the Ram anyway since the guys at Rockland Standard Gear in New York suggested to do so(very rude people wouldn't suggest anyone to deal with them).
I got car together yeasterday thank god as I beat out the winter snow here today in Chicago so I got 25miles on the new trans. All seems perfect no issues on shifting very good clutch as well(never shifted over 3k). Now the problem is its leaking again!.... I can't seem to find where the leak is comming from(just as before) It seems to be from where the rear part of case meets the front part(where 4 bolts connect them),but not where it meets bellousing but right infront of the x member.
Please help im leaking this damn expensive syncromesh fluid and we all know its not cheap( i'v been thru alot of it in the past year saving every drop so can filter it later)
I appreciate all your guys/gals help
I can send you pics if you are really interested in helping me solve this problem.
thanks you all alot ,
Kevin
