TKO tranny problems.... Need help
  • Thread starter Thread starter diablostang
  • Start date Start date Aug 30, 2005
diablostang
425
Raleigh, NC
Aug 30, 2005
  • Aug 30, 2005
I've got a 94 Mustang Gt, got a TKO 3550 <I believe> tranny in it, and lately, I've been having some trouble with the gear shifting..
Sometimes it's as if the gears are totally locked out, this only happens when stopped, going into first. Most of the time I can fix it by going into 4th, <not letting the clutch up> then it'll go into first fine.. Anyhow, this didn't seem right at all, and it's pretty bad when you're in traffic, trying to go.
Any thoughts, opinions?
Thanks
Aliate X
602
Rockland NY
Aug 30, 2005
  • Aug 30, 2005
My T-5 did that, it also whined extremely loud.
Blew up 3 weeks ago.
diablostang
425
Raleigh, NC
Aug 30, 2005
  • Aug 30, 2005
ouch
The TKO is also rattling under acceleration....
V
v8only
2,378
22
49
Aug 31, 2005
  • Aug 31, 2005
sounds like a clutch adjustment possibly.
where does your clutch grab? If it grabs super low to the floor, you're too loose, tighten your adjustment up quite a bit. If you don't know how to do that, read my article.....
http://50stangs.com/techarticles/clutchcableadjustment.html
diablostang
425
Raleigh, NC
Aug 31, 2005
  • Aug 31, 2005
Naw, it's not a clutch problem. The clutch engages where it should <stock engage position>
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Aug 31, 2005
  • Aug 31, 2005
Before you pull it out and assume it's time for a rebuild, I would simply change the fluid with some GM synchromesh. Check the fluid that comes out of it for metal particals. This may give you a better idea of how, and if, it is bad.
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Aug 31, 2005
  • Aug 31, 2005
The fluid change rarely works, i'd say it's more of a "hail mary" than anything.
If it's really a tko, get it fixed now, before it's just a pile of scrap metal.
As you read above, from someone elses experience, it will get worse quick.
diablostang
425
Raleigh, NC
Aug 31, 2005
  • Aug 31, 2005
It is a TKO, I just wasn't sure if I got the model # right.
Sigh... Well I guess I'll take it to a tranny place and see what they say.
2000xp8
Aug 8, 2003
8,075
1,658
194
NJ
Aug 31, 2005
  • Aug 31, 2005
Make sure you take it to a place that knows what the hell they are doing. Don't just take it to some chain trans shop.
If you can't find someone locally it may be best to take it out yourself, and ship it to hanlon.
This is NOT going to be easy on your wallet, just so you know.
Right now, it sounds like you need a simple rebuild with the basic small parts, if you keep driving it, you will need more, probably will exceed the tranmissions value if you break some real.
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Aug 31, 2005
#10
  • Aug 31, 2005
  • #10
I live about 5 minutes from Bob Hanlon ... makes it nice when I have a tranny issue (knock on wood) He redid my t-5 a few years back .... before it went KABOOM!!! I understand you are in the mindset of a rebuild but I would really change the fluid prior to doing that. Sure it may not work but it will only cost you about $20-$30 and some time to do it. Sounds like the synchros are either going south or your fluid is crap/low. I understand 2000xp says the fluid doesn't work but if you change the fluid, see a bunch of metal pieces then at least you can say "I need a rebuild" whereas if you see no metal pieces, and the trans shifts smoother then you just saved yourself a rebuild. Worth the time in my book The tremec rebuilds are NOT cheap either
2000xp8
Aug 8, 2003
8,075
1,658
194
NJ
Aug 31, 2005
#11
  • Aug 31, 2005
  • #11
By no means am i saying to not try the fluid change first, i just don't want you getting your hopes up on it.
Aliate X
602
Rockland NY
Sep 1, 2005
#12
  • Sep 1, 2005
  • #12
diablostang said:
ouch
lol mine did that too in 3rd gear, start saving for a new trans.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
