TKO tranny problems.... Need help
diablostang
425
Raleigh, NC
I've got a 94 Mustang Gt, got a TKO 3550 <I believe> tranny in it, and lately, I've been having some trouble with the gear shifting..
Sometimes it's as if the gears are totally locked out, this only happens when stopped, going into first. Most of the time I can fix it by going into 4th, <not letting the clutch up> then it'll go into first fine.. Anyhow, this didn't seem right at all, and it's pretty bad when you're in traffic, trying to go.
Any thoughts, opinions?
Thanks
Before you pull it out and assume it's time for a rebuild, I would simply change the fluid with some GM synchromesh. Check the fluid that comes out of it for metal particals. This may give you a better idea of how, and if, it is bad.
The fluid change rarely works, i'd say it's more of a "hail mary" than anything.
If it's really a tko, get it fixed now, before it's just a pile of scrap metal.
As you read above, from someone elses experience, it will get worse quick.
diablostang said:
It is a TKO, I just wasn't sure if I got the model # right.
Sigh... Well I guess I'll take it to a tranny place and see what they say. :(
Make sure you take it to a place that knows what the hell they are doing. Don't just take it to some chain trans shop.
If you can't find someone locally it may be best to take it out yourself, and ship it to hanlon.
This is NOT going to be easy on your wallet, just so you know.
Right now, it sounds like you need a simple rebuild with the basic small parts, if you keep driving it, you will need more, probably will exceed the tranmissions value if you break some real.
I live about 5 minutes from Bob Hanlon ... makes it nice when I have a tranny issue (knock on wood) :D He redid my t-5 a few years back .... before it went KABOOM!!! I understand you are in the mindset of a rebuild but I would really change the fluid prior to doing that. Sure it may not work but it will only cost you about $20-$30 and some time to do it. Sounds like the synchros are either going south or your fluid is crap/low. I understand 2000xp says the fluid doesn't work but if you change the fluid, see a bunch of metal pieces then at least you can say "I need a rebuild" whereas if you see no metal pieces, and the trans shifts smoother then you just saved yourself a rebuild. Worth the time in my book :shrug: The tremec rebuilds are NOT cheap either :(
