what would you guys go with to power my 500hp 347 stroker motor please post any issues with either tranny
At that power level, either tranny will work. However, the T-56 is a much stouter tranny with a lot more room to grow. I would go this direction if you plan to push over 600 rwhp in the future. I also have a personal preference for the .50:1 6th gear instead of the standard Cobra .63 (?) 6th. Why get a 6 speed if the 5 speed has a nearly identical overdrive. The .50:1 gear lets you get away with a numerically higher rear gear while still pulling down the rpm and increasing mileage on trips.
Chris
I havent heard a lot of people that are happy with the tko600
I know you can get parts for the T56 if you need them. It is also easy no get T56 information. The TKO600good luck. I see the T56 as being more piratical.
what does a tranny have to do with pirates![]()
good luck. I see the T56 as being more practical" If you can afford the viper spec, get that. No question in my mind.
That should have read "I know you can get parts for the T56 if you need them. It is also easy no get T56 information. The TKO600good luck. I see the T56 as being more practical"
Spell check will insert things I do not want and times.
