TKO600 VS. T56 Viper Spec
Which Tranny
  • Total voters
    30
Viper t56 good for lots of power shifts smooth as a t5 no weird vibartion problems just an all around great trans mission. I have an older vipert56 from d&d it has a final drive of .50. Really great when I was running a 4.10 gear. That being said I ran that trans on my NA set up and now I am turbocharged so now I run a 3.27 gear. Gives the turbos room to spool before you run out of rpms. Any way so now I could have run a tko and still been fine on the highway. Still like the viper even if my 6th gear is kind of a waste. By the way don't confuse the t56 for the viper t56 big difference, both strength and money wise.
For a high HP build I tend to trust a built 5 speed more than a built 6 speed in holding the power more. Either choice won't be wrong.
Kevin
Go and take a look at how many big turboed vettes, Vipers, Supras, and stangs are running 5-speed. In particular, look for the ones making around 1000 lbs-ft or more. I think you'll be surprised at what you find. It's the big displacemnt turbo/screw/roots cars you should be looking at. These are the cars that are going to overwhelm the tq ratings on TKO600s. There are a lot of T56s that are alive and well behind cars like these. I used to think the same thing of 5 speeds, but the evidence out there did not bear out this belief.
Chris
The TKO600 is rated at 600 lb/ft tq. while the Viper spec T56 comes in at 650 lb/ft. So as has been said numerous times already, either tranny is fully sufficient for your numbers. Cost will be significantly higher for the T56 but you'll have the availability of the extra gear. How many people actually utilize that extra gear remains to be seen...
I hear many people complain about the shifting difficulty with the TKOs. This is true for the first 500 miles, at the most, until it is broken in. After such time, these transmissions shift like greased lightning. The reason is the rail system. The TKO is a triple-rail linkage system while the T56 is a single for smooth and quiet operation.
Much discussion is made about the internals of the respective models and I will consistently opine that the TKO models are more durable than the T56 variants. The T56 was designed for "luxury" sports cars with smoothness and noise reduction in mind. (Just look at the vehicles it comes in: Viper, Vette, Cobra, Aston Martin.) The TKO, on the other hand, was designed specifically for high-performance racing applications.
It all boils down to your pocket book and how you intend to use it.
slow95gt said:
all I will say is I LOVE MY TREMEC!!!!
Tremec makes both the TKO and T56. :nice:
I can see that my opinion on the T56 is not the popular one. Here are a few posts on a different message forum from guys that run them:
Don't count out the importance of a nice clutch setup in your search for manual transmission bliss.
Rockland Standard Gear offers two transmissions of note: The "Tranzilla" is their baddest-of-the-bad T56, it has the 'Vette-style, triple-cone synchro's, 9310 gears/shafts, steel shift forks, solid keys and rated to handle 1200hp/1000lb-ft, etc. ...............and it's $8500. No, that is NOT a typo', it's a quote for a GM musclecar application that I got for my Chevelle. The company must've gotten a rash of **** over the price, as they now offer a "Son of Tranzilla" that is pretty much a clone of the Viper-spec' units that are on the market elsewhere. The Son-of trans' is $3150 and is rated to handle 800hp. Their ad' runs in the last 10-15 pages of Hot Rod just about every month.
D&D is another company that offers a strong T56 and it has pretty much the same mods and specs as the Son-of trans' from rsgear.com. It's also priced about the same, $3150 and there are ALOT of members on here that use it with success.
Richmond Gear offers the R.O.D. six-speed, it's rated to 450lb-ft nowadays but I've got an older Doug Nash ad' that rates the trans' at 650lb-ft (Nash 5spd. is a clone of the R.O.D., minus the 6th gear and related pieces and minus the 9310 gears that they build 'em with nowadays.) The six-speed's got a billet steel input shaft retainer, roller mainshaft gears and some pretty nice features. They want $3019 today in Summit's Nov./Dec. catalog, I got mine from Jeg's back when they were about a year old and paid $2820 when Summit was $3029 (figure that one out!?) I've never seen a R.O.D. user break their trans' due to "too much power/torque", maybe some from abuse. When mine breaks, I'll cuss 'em but, then again, I drive my car as if I actually paid for every part/piece on it (which I did.)
Another company that makes a strong T56 is G-Force, although the last time I checked on pricing (which was over three years ago) they priced them at $5650 and rated them to handle 900lb-ft. I've heard mostly good things about G-Force units in high-powered street cars.
There's a couple more companies that offer strong 6spd. transmissions, just do some searching (bright Green button) for maybe the words "strong" or "strength" and "T56" (and also "T-56", with a dash) as well as the obvious "manual" and "trans" or "transmission". Two of the members on here that use T56's are Wolverine and Danimal95, PM 'em and pick their brains, they're both pretty sharp cats.
Row yer own!! Good luck!
---==Temio Williams
Yuba City, CA
danimal owns a 1000+ rwhp twin turbo mustang with a G-Force T56
danimal95 said:
myself and intmd8 have broken about every 5 and 6 speed trans outhere that is ok for street use.We have both exploded the 3rd gears in multiple t-56's with viper parts,which really dont help if your making in excess of 850rwhp,i have blown 3rd gear out of a mmr tko900,and been through several clutches as well.Now heres what will hold up to seriou hp,get a g-force t56 and a mcloed twin disk clutch,spend the money once in the right parts and not alot of wasted money in the wrong parts.We have both been running this set-up for several years now with no problems at all,the newer g-f t56's are almost as quiet as stock and basically indestuctable.He ahs gone mid 9's at 150 on 2step launches a dozen times powershifting all the way down the track,plus we have done hundreds of full runs on the streets through 6th gear.Also you should now that when we broke the other trans's the cars where on radials on the street just doing 3rd gear roll ons.
twinturboGT said:
twinturboGT,
What exact transmission did you have?
Built to the gills G-force T56. I made one pull on the dyno that made 1260 RWHP 1200 RWTQ at 21 psi and the tranny was fine. I was cruising around on the street at 15 psi on pump gas and it broke on a 3rd gear pull, I was on 18" MT drag radials. At 12 psi off the wastegates it made 970 RWHP 950 RWTQ, so I figured at 15 psi it was making around 1100/1100 at the wheels. Keep in mind this was in a very, very heavy SN95. I've got a full cage, big stereo with 2 x 12's, the big 9.5 deck motor, two big 74mm turbos, a big intercooler, big rad, meth kit in the trunk with a 6 gallon cell, full interior (front and back seats) with added dynamat all over the car. I'd venture 3700+ pounds with me in it.
ROGUEGTS said:
Those viper spec G-force T56's are no joke at all, more than a couple have held up to TT vipers running deep in the 8's @170+ and 1500+ rwhp dyno pulls. You have to be a little careful with how you shift a car like that, but they are probably the strongest "normal" trans you will find, w/o going to a lenco, bruno, etc.
This guy owns a 1000+rwhp mustang with a G-force T-56
INTMD8 said:
IMO, the MMR TKO or the Spec stage 5 clutch will not take that power.
Maybe it was just an anomoly, but a friend of mine broke 3rd gear in the 900 and has switched to a G-force T56.
His spec stage 5 was slipping with 900rwhp/700-ish rwtq, and was switched to a Mcleod twin disc.
Willie (Wolverine) has an SN95 that currently pushes almost 1200 rwhp through a G-Force T56. Here he actually says something negative about G-Force, but he never went into any actual detail:
WOLVERINE said:
I get around 100 PM around all the forums of people asking me what tranny, I used on my car. The only reason, I dont tell people is because the company did me wrong. I am not goin to talk bad about them. I only help company that are str8 with me. Now MCleod clutches are the ****...
More from WOLVERINE
WOLVERINE said:
This tranny are good. I drive around in a 800hp car on low boost every day and play a lot on the street. The question you need to ask your self is how long this tranny is goin to last you before it start to make noise? Most of this 7/8/9 second cars are track car and, when they brake they dont tell anybody. They only post the good one..
Here's some info on various TKO catastrophies. Keep in mind that the X2C V1.0 is the same tranny as the MMR900:
pdp 93GT said:
I have an X2C Motorsports V1.0 TKO from January 2003. I am the fourth owner of this transmission and broke some of the teeth off of the third gear cluster a few nights ago. I tried contacting Modular Mustang Racing but all they want to do is sell me a new one. I am thinking about shipping it to Liberty Transmissions for a rebuild and would like for it to be rebuilt with the same 700HP rating as before..
only306 said:
Please HELP!!! For three seasons I've been running a TKO 600 in my street/strip T-76 turbo mustang. The car weighs 3400#, 3.55 gears, 306cu and on a chassis dyno made 800hp 850tq. I've broke the TKO 5x now and I'm sick of fixing it. I want to put a somewhat bulletproof Turbo 400 and want some info about Bell housing, crank adapter, flexplate, driveshaft mods, crossmember, speedo cable mods, etc, etc.
Steed 93 has a fox with a TKO:
Steed93 said:
I have never been to a dyno, but my times are listed below. I would guess about 500-550 rwhp. I sheared a few teeth off third gear and also sheared both keys 50% while doing a 3rd gear pull on a local road.
NigelTufnel said:
Last year I had a TKO-600 in my 3,900 lb Challenger with a procharger making 650 rwhp 708 rwtq on 10 psi and the trans was ok. This year I swapped the procharger for a GT47 turbo (no other changes) and made 838 rwhp 871 rwtq on 10 psi. First time I went to the track with the turbo I broke the input shaft (snapped like a twig). I'm running a powerglide now.
94scstang said:
I have one I will be selling here soon it has about 20 runs at the strip on it at 5psi then i set my boost to 15psi and it snapped my TKO like a chicken bone. This clutch will hold what ever you have. Pm me if you want it.
94scstang's sig reads:
94 GT T70 Cartech Outlaw kit
352 CI" Dart block
611rwhp 734RWTQ so far
Big Jay said:
FYI the TKO900 from MMR will not last. Mark Luton broke quite a few before getting it to do 8.9. The he broke a bunch afterward. Now he has an auto. TrentK (the owner of this site) has a tko900 and broke his at about the 700-800whp level. If you want reliability get an auto. Or find a way to make the Supra 6-speed fit. NOW THAT IS A BAD ASS MANUAL.
I have a point of contention about those supra getrag 6-speeds, though. They may be found behind 1000+ rwhp supras, but keep in mind that those cars are making that power at upwards of 8-9000 rpm. That means that they're making a lot less torque than the mustangs making the same power at 6-7000 rpm. That makes things a lot easier on the tranny.
Anyway, I hope this helps someone out there. Just because TKOs will not break in 98% of street built cars doesn't mean that it is a stronger design than the T56s out there. The two companies that have a great reputation are Rockland Standard Gear, and G-force. Going with the TKO will give you all the strength you need for now, and it will be cheaper. I personally wouldn't even bother paying the extra dough for the MMR900. They don't even have to weld the keys anymore. From what I gather, pretty much all they do is cryogenically treat them. It will not be stronger than one of these top of the line T-56s. If you want the best, bring your wallet. You're looking at more than $5k for the G-force and around $8k for the RSG Tranzilla.
Chris
Chris
Very true. I have no doubt that there are plenty of 6 speed powerhouses out there. In fact I will be backing my 428 with a t56 one of these decades... hehe. I am just coming from the standpoint that it will be cheaper to build up a 5 speed to handle more power. Any time you stretch huge power over more moving parts, it does affect strength. Money being no object, anything is possible but I don't see the mustang as being a supercar though it can be made to contend with one.
Kevin
With all the bad I've heard about TKO500's and 600's I'd get a T56.
MY Cobra's stock T45 has been great for the past 5 years with a supercharger....I actually just had my transmission shop take it all apart for inspection. I needed a clutch and I have long tubes, so I figured better pay some extra cash for an inspection while it's out. They said they couldn't find anything wrong with it, so they put it back together with all the original parts. I don't power shift, or do 5,000PRM clutch dumps either though.
Friend of mine broke a TKO600 that was built for drag racing, had 2nd and 3rd gears hard faced, had the gears built with a "dog tooth" to make upshifts faster and easier, (a S.O.B. to downshift tho) ect. Had a Mcleod dual disc clutch blah, blah blah. Needless to say spent a ton of $ on trans and drivetrain. It worked real good for about 1 year and then 1st gear blew out on launch. I would venture to say a T56 would not have lasted much longer either as the car weighed 3,400 lbs, and made 625 lbft torque at the tires at only 2,200 rpm. 331 cid, Kenne Bell @ 18 psi (15 psi at the motor). So when all that torque hit the slicks when he dumped the clutch that 1st gear did not stand a chance. Rest of the trans still looks new, but 1st gear is toast. :D
