Tokico HP Struts/Shocks... Any good??
They're what I have and I really like them (with a mild drop - I cant speak about really lowered cars and how they dampen).
EDIT: I just have the dampers - I have Eibach springs.
I'm running those with Eibach Springs the car was lowered 1.3 Fr & 1.4 Rear. The ride is firm, not overly rough with the 18's & low profile tires. It was really smooth with the old tri-bars & stock tires.
I'm also thinking about replacing my tie rod ends, cuz while driving down the road, the front end pulls to one side or the other. And when I get the front end off the ground, I can grab the sides of the tires, and ever-so-slightly wobble the left/right, but not up down. Would that indicate bad tie rod ends? I want to make sure I do the whole front end right when I lower it, to get the best ride/handling.. ?? :SNSign:
I'd try and narrow it down further - play as you described is more likely to be inner tie rods than outers in my experience.
Good luck.
