Too much injector for this setup?
NOSNotch
577
South Jersey
I've got a freshly built 306 with ported twisted wedge heads, a street heat intake, 70mm tb and a custom grind cam w/about .560 lift. I have a full Aeromotive fuel system for it w/braided line, rails and an A1000 pump. I have a set of 30lb injectors for it right now but i've been hearing thats too much injector for my setup. Would you guys recommend 24s over the 30s? Thanks alot
Kevin
I say you'd Be best off with 24's unless you plan on doing some power adders later..the 30's are a little big and you would have to bump the fuel pressure down to much and the spary pattern of the Injectors wouldnt be correct.
