And after driving it there and the brakes going out I dont care if they paint it pink with purple polka dots and dust in it.
I had my car running fine, what happened, I blew a brake cylinder? Car pulled severley to right when brakes applied, then pedal kept fading and going down- had to pump the brakes and really went slow getting there, cause time is tight and theres no way i was gonna turn around.
Plus I bycyled the 12 miles getting home-
But I had the car 90 % prepped by a friend, and everthing is off the car- I didnt know a car could run with out an insturment panel!
So heres the deal- sharpen all body lines - paint underhood, jambs and trunk, paint inner doors, dash, rear inner panels, and steering column, with Ford Redfire metallic, and paint outside of car with same but with a clearcoat.
1000 even. Thought that was a pretty good deal, and he also said that he would call me after all prep and before car is sprayed to inspect work and see if anything needs to be tweaked.
2 weeks. Well see.
2 weeks. Well see.
