Toploader swap
Anyone here ever do a 3 to 4 speed swap in a big body? I want to get rid of my 3 speed in my '71 Coupe and am curious as to what it will take, I would like to run a toploader 4 speed. The motor now is a 250, but it will soon be a 302. Thanks in advance for the help.
Chris
Depending on the positioning of the 302 vs the 250, you may need a different driveshaft length ( even if you keep the 3 speed) Some Toploader 4 speeds have longer tailshafts than others ( the Galaxie units are 3 inches longer than the Stang/Fairlane ) There are also different shifter positions on Toploaders for different cars. I would wait til you get the 302 in before buying a 4 speed. Then see if the transmission's position has changed. I don't think it will, but you never know when doing engine swaps, especially from a 6 to an 8. Most likely you will need a 4 speed with similar dimensions as your 3 speed.
