Torq Performance
  • Thread starter Thread starter Deleted member 38176
  • Start date Start date
I’m with Winters98GT on this, It doesn’t matter how talented you are at tuning there is no way to get a proper tune without running the car. What you will get is a box tune that worked well for a car with similar modifications, more than likely they will pull a little timing and add a little fuel to make sure it is safe. I’m sure it will work and will make the car run well but it’s obviously not going to give you the peak performance. I would either buy the necessary equipment to tune your own car or take the car somewhere to have it dyno tuned.
First off which cams are you looking to install on the car? An email tune will be able to get you real close with the cams and most companies offer this now. As Mark stated tuning the car on the dyno is part of the equation but street tuning is where you will get the driveability and performance instead of just a number. That is why I used Torq on my last few cars as my cars weren't just laying down good numbers at the track; but they were daily drivers and were smooth the entire time while some other tuners left me with a real touchy throttle and the car was a task to drive if just wanting to cruise.
It doesn't hurt to do some datalogging on the car but I think you'd be surprised how close the tune will be from the start. I have no doubt Paul will provide you with a good tune and I suggest you mention that you talked to Maddox about it ;)
I was looking at the MHS stage 2 cams. I want to dyno tune it but my nearest tuner is 300 miles away and I figured that a tune like this could hold me over for a while until I had the time to make the trip.
The email tune will be fine for you and shouldn't be an issue to get dialed in with some datalogs. If you were doing extensive work to the car other than just cams (such as ported heads, cams, blower all paired together haha) then it would be likely difficult to fine tune.
