Fox Torque converter suggestion
I have a 83 GLX with a 302 and a AOD transmission. I have the PA second gear hold valve body and using Jegs Quick shift fluid and a Jegs filter, also bought a B&M shifter. All I need now is a torque converter. My 302 is just bolt on 4 barrel carb and long tubes, and I have a Nitrous Express plate kit on a 75 shot. I plan to do a very mild cam in the future. I mainly am going to use this car for average joe class 1/8 miles dot tire drag racing and cruise into town on occasion. What converter do you recommend?
I dont have a recommendation for particular brand. I just sold a used Trans Specialties 3000 stall for AOD. I pulled it from the 93 since I've been de-tuning that car back towards stock. I rebuilt the transmission and put a stock converter in.
Someone should chime in with brand recommendation.
I went with an edge 2800 stall lock up converter in my 93. I have a silverfox valve body and the engine is a stock lower end with afr heads and an Anderson ford cam. Combo for me is great but it's a street only car.
