Torque Convertor install question
  • Thread starter Thread starter Jack's95gt
  • Start date Start date Dec 11, 2005
J
Jack's95gt
443
Huntingdon Valley, PA
Dec 11, 2005
  • Dec 11, 2005
I have a AOD from a 1990 5.0 converable. I'm installing the torque convertor on the transmission. It goes in with three steps. After I have it in as far as I can get it, I took measurements with a straight edge and scale. I'm 3/16" from the center hub to the plane of the housing and it's 15/16" from flat right by the stud for flexplate connect to the plane of the housing.
My Haynes Mustang manual doesn't cover this subject. I need to know if it's installed properly.
J
JB66
565
New York
Dec 11, 2005
  • Dec 11, 2005
There are 3 items that need to engage on a torque converter. #1 is the input shaft into the very center. #2 is the external splines off the front pump to the internal converter splines. #3 are the 2 'flats' (do they still use them?) on the external converter tube into the cooresponding flats which are part of the front pump. Install the TC without the input shaft to make sure it fully seats like that. If it does, your problem is getting the input lined up. Make sure the converter still wiggles easily BEFORE you tighten the housing bolts! (and after)
J
Jack's95gt
443
Dec 11, 2005
  • Dec 11, 2005
It sounds complicated. I was hoping that there was a measurement like I see for other cars.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
20K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
