torque monster?
  • Thread starter Thread starter myslo50
  • Start date Start date Nov 19, 2006
1 of 2 Next Last
myslo50
247
ohio
Nov 19, 2006
  • Nov 19, 2006
i think this will be a tech question but if it doesnt feel free to move
im trying to get a resipe for a torque monster. im saving the fuel inj on my car.undicided on a 306,331,347,351,393,408.i dont want to rev past 6000 r's
and if i can use a cast iron head it would be great. point me into the right direction. i have 3-302 blocks and 1-351 block to work with. i have a explorer intake on my 302 now and if i use a 351 i will have to find a lower, therefore i want to have, whatever i use, to look like is somewhat stock. i dont care about the sound.
there was a post a couple of days ago there a guy took a rebuilt 351 with a dish piston, afr's and a carb and was laying down like 450 at the crank i think. i was likeing the idea of that i will be using a t-5 for now and 3.73. i gonna talk to a machine shop for some assistance too.
if anybody has a setup like i want please post the parts so i can print it out
enyawix
507
Nov 19, 2006
  • Nov 19, 2006
Use a 1.5” intake manifold spacer. This will give you more torque. Also no more than 2.5” exhaust pipe, also use small headers. Use a small cam. Do not use a big throttle body, 65mm is fine.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Nov 19, 2006
  • Nov 19, 2006
go with like a 428 stroked 351, that would be better for torque.
Mavrick
2,264
Collingwood, ON
Nov 19, 2006
  • Nov 19, 2006
More cubes, more torque! Go 351w, even stroke it!
Intake spacers are a joke, forget that. More trouble than they are worth.
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
West Coast Best Coast
Nov 19, 2006
  • Nov 19, 2006
Stroke this stroke that,ahhh! I say go 460!
A mild build will net you over 500lbs. of the stuff. If your not into the BB then go for a Turbo/SC. Just make it a bullet proof bottom end and you can just go super mild up top.GT-40 or worked E-7's, stock cam,OR if you wont a rumble get an alphabet cam.Cobra intake or used GT-40 Then add some boost!
Boost equals GOBS of torque.
ExplodingGopher
517
The mistake on the lake (Ohio)
Nov 19, 2006
  • Nov 19, 2006
i say go with an 872ci big block ford, i think it makes a couple thousand ft.-lbs. of tq N/A
enyawix
507
Nov 19, 2006
  • Nov 19, 2006
when was a 872 made and what was it in?
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
Nov 19, 2006
  • Nov 19, 2006
Sherman Tanks?
Nopantz
234
NJ/US Merchant Marine Academy
Nov 19, 2006
  • Nov 19, 2006
try a nicely dressed 331 with a 2.2L Kenne Bell on it....would be alot of fun if you can ever get the tires to stop spinning
ExplodingGopher
517
Nov 19, 2006
#10
  • Nov 19, 2006
  • #10
an 872 is a custom race block. it wasn't production in anything. the block costs around $13,000 i believe.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Nov 19, 2006
#11
  • Nov 19, 2006
  • #11
will it run off pump gas?
myslo50
247
ohio
Nov 19, 2006
#12
  • Nov 19, 2006
  • #12
maybe ill stick with a 331/347 set up, that way everything is guaranted to fit. i dunno, i like the theory of a 351 with iron heads and gt-40 intake. its soo hard? i really dont want to do boost even though it makes power but for a sweet s/c its like 3500 then i would have to buy an expensive block, and i dont think i want to that. i got a 302 and a 351 block to choose from, im undecided?
ExplodingGopher
517
Nov 19, 2006
#13
  • Nov 19, 2006
  • #13
hahahaha.....probably not
ExplodingGopher
517
Nov 19, 2006
#14
  • Nov 19, 2006
  • #14
go 351
myslo50
247
ohio
Nov 19, 2006
#15
  • Nov 19, 2006
  • #15
theres another article in the tech right now that explains the 351 vs 302 and i thing im gonna try the 351. im gonna talk to my machine shop tomorrow about a rebuild, i might hunt around in the junkyards for a lightning 351w, cause the 351 i got is a flat tappet block. ill check out the price diff.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Nov 19, 2006
#16
  • Nov 19, 2006
  • #16
You don't want bigger than 2.5 unless you're running a LOT of cubes (like 426+) or some serious forced induction or turbo.
Also, cubes are the magical torque maker. You definately want a long runner intake, and you definately want full length headers and full exhaust.
Flavadave4
1,044
21
49
Utica, NY
Nov 19, 2006
#17
  • Nov 19, 2006
  • #17
408w
myslo50
247
ohio
Nov 20, 2006
#18
  • Nov 20, 2006
  • #18
i think im gonna hunt me down a lightning 351w and go from there. i know they have gt-40 heads and i can have them ported as well with a gt-40 intake. ill defenatly go with long tubes and a just gotta run 3" exhaust. ive wanted 3" for a while, i dont care if i loose 5 hp over it.
i think the car will sit nice also when i install my motorsport b lowering springs.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Nov 20, 2006
#19
  • Nov 20, 2006
  • #19
ABSOLUTLY incorrect!
I have a small 347 and my combo NEEDS a 3".
The 3" exhaust will help my engine make more power from idle to 7000 rpm
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Nov 20, 2006
#20
  • Nov 20, 2006
  • #20
HP sure but what about torque? How many 400+hp musclecars came with 3 inch exhaust? Sure, back then they didn't put much performance in exhaust but those cars made retarded torque. I've always understood that 3'' is great for high HP numbers but hurts torque.
1 of 2 Next Last
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
9
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
