torque specs
  • Thread starter Thread starter 91lxstang
  • Start date Start date Sep 3, 2004
9
91lxstang
191
Reno, NV
Sep 3, 2004
  • Sep 3, 2004
Well I'm getting ready to slap my new heads on tomorrow. And I need the torque specs, for the rocker stud bolts? And the head bolts? The heads are TFS TW if that helps? Also what is the pattern to install the head bolts?
Thanks!
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Sep 3, 2004
  • Sep 3, 2004
Head bolts - with clean threads lubed with oil - 75 ft-lbs; lubed with moly lube-65 ft-lbs; rocker bolts 20 ft-lbs; lower intake - 16-18 ft-lbs.; upper intake 10 ft-lbs. Get a manual for the proper patterns - especially the lower intake.
9
91lxstang
191
Reno, NV
Sep 3, 2004
  • Sep 3, 2004
Is that for the studs to the heads? Or the other ones that lock the rocker to the stud?
Thanks!
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Sep 3, 2004
  • Sep 3, 2004
Sorry - I misunderstood; thought you meant rocker bolts. You'll have to post separately and ask others what torque (if any) gets put on the stud - it's probably just til they bottom. The nut doesn't get a torque put on it. It simply gets tightened a set number of turns - usually between 1/2 and 3/4. Be sure you loosen the allen lock nut down inside - tighten the nut the number of turns, then set the allen lock. That always gets done when the lifter is on the base circle of the cam - not the the lifter's on the lobe. You'll have to rotate the engine by hand for each set so that the valves are closed when you install them (base circle).
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
