Ok, time to start the motor for the first time. It's a 5.0 out of a 1985 Grand Marq. It was FI to start with. I have totally went through the engine, AFR heads, stroked to 347. Now for the important stuff: Trick Flow Street heat cam, (roller hyd) stock distrubitor with a MSD 6AL connected to it and MSD cap. The Haynes manual I have for the Grand Marquis states the firing order as 1-5-4-2-6-3-7-8. I have been trying for 2 days now to get it started. It wants to run so bad, but will not run. It tries to run, is getting fire, but will not run. I changed out the FI intake, with a 4 bbl intake and Holley (also rigged up a low pressure fuel pump). No change in starting, the distrubutor has been in and out, moved one tooth, each way without help. Last night it did backfire 2 times (had not been backfiring). The last time it blew the muffler cases apart. Looking at Trick Flow web site, it shows the firing order at 1-3-7-2-6-5-4-8. Tried that, it doesn't even try to start now. So I changed everything back. Found TDC made sure that the rotor is pointing at the #1 cylinder at about 6 - 7 degrees BTDC. (Does it matter which terminal you use for #1 as long as the rotor is correctly pointing at the #1 plug when it should). I'm lost, I know I am getting fuel, I know I am getting spark, I even moved the timing 180 degrees just to make sure.
PLEASE HELP BEFORE I SIT FIRE TO IT.
Going to go back from ground 0 tomorrow. One thing I picked up on from the first reply. Since this has a hyd roller cam, I was under the impression that no valve adjustments where needed. I'm having some problems with the timing marks. I am running the late (85 model) balancer with an early timing cover and early water pump (standard rotation). I'm not sure if the early pointer is in the correct position. Here's what I did to work through this: I have an adapter that allows a dial indicator to screw into the plug hole. While turning the engine over by hand, I watched the indicator until I found the highest reading (piston at top of cylinder). Problem is the piston stays on top for a couple of degrees before starting down. I am just holding my thumb over the empty plug hole to feel for compression (one or both valves should be open during exhaust stroke depending on overlap of the cam). I feel solid that I am on the compression stroke, but really guessing where 10 degrees BTDC is going to be (center of highest indicator reading + maybe 1/4" of movement of the balancer (clockwise). The rotor is then aligned to a sharpie mark on the side of the lower dist cap adapter. The mark is directly under the #1 terminal on the cap. This may not be perfect, but I think it should be close enough to start. Turning the dist clockwise seems to tighten up the motor while I get more backfires by turning it counter clockwise.
