Sorry if this has been asked before but I've tried searching several different times and haven't seen anything.
My stang has had a rough idle for awhile now that seems to be getting worse. It also tends to stall when cold. I've noticed that engine bogs a little when I step on the gas after shifting when cold. I've already cleaned out the IAC and adjusted the idle so I'm thinking the TPS needs adjusted or replaced. The only problem there is I'm not quite sure where the TPS is. I get that its near the intake and throttle body somewhere but there seems to be a whole lot of plugs and wires in that area, none of which look to have the screws to adjust.
Eventho has a really nice write up in here somewhere but it's for a Turbo 2.3 and the pics don't show up anymore so it doesn't help location wise. Can anybody point me in the right direction or, even better, have any labled pictures?
Also, I wondering if the check engine light would be on if the sensor is bad because it's not. It does occasionally flash around 3,000 rpm which I'm thinking would be the 02 sensor. What can ya tell me?
