Psydwaze said:To test the voltage, probe the green wire (+) and the black wire (-).
key = ON
engine = OFF
I've heard on some sensors you may need to open the holes up a bit to get close to 1.00 but I did not have to do this on mine to get .97v
TK_05 said:i dunno i fixed mine and it seems to be running better.. deffinately idles alot smoother..
stang&2Birds said:Yours was over ~1.1V at idle. So, either you have an aftermarket TB, the idle stop was adjusted, or someone else screwed with the TPS before.
Also, never forget the Placebo effect. Placebos were the first pre-made prescription pills to be sold in the U.S. They came in different colors and flavors. There were even suggestions on which one "worked best" for certain aliments.
