TPS Sensor Accuracy???
  • Thread starter Thread starter lead09
  • Start date Start date Jun 7, 2006
lead09
25
  • Jun 7, 2006
How repeatable is the idle setting supposed to be? Key on engine off I set it at 0.990V w/ engine on it was 1.007V. I then re-adjusted w/ engine running to 0.970 to make sure it stays under 1 at idle. You can really hear a difference when adjusting past 1V at idle.
Is this ok or it my sensor garbage? I sprayed some oil on the idle return spring. Can I get a heavier one?
Thanks.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Jun 7, 2006
  • Jun 7, 2006
Thanks.
the alternator charging will actually make it go up slightly especially if you have a 130 amp alternator upgrade .....so set it to .95-.97 with the engine running and you will be fine ........
HISSIN50
34
129
Jun 7, 2006
  • Jun 7, 2006
Actually, my understanding is that one reason for a VREF of 5 volts is to remove the voltage fluctuations that the charging system introduces.
You dont post a year of stang, but there's a good chance that it zeroes out upon start up anyhow.
Just MHO.
Good luck.
vristang
4,933
101
124
Seattle
Jun 8, 2006
  • Jun 8, 2006
In my opinion most people don't really care about what the tps is with the engine off.
I have always set mine with the motor running.
One of the EEC tuners that I respect alot (Clint Garrity of EECAnalyzer) sets his tps to .95v. I see no difference when setting min that low.
I think the only thing it would affect would be when the tps trips open loop.
This would be a minor impact.
random thoughts by
jason
lead09
25
  • Jun 8, 2006
It's a 1990. The rest should be in my sig.
vristang
4,933
101
124
Seattle
Jun 8, 2006
  • Jun 8, 2006
JT-
I would be curious to hear what years zero out the tps. Maybe you can provide some info on how the puter does this?
jason
HISSIN50
34
129
Jun 8, 2006
  • Jun 8, 2006
All 89-93 MAF puters should AFAIK (Per Probst).
vristang
4,933
101
124
Seattle
Jun 8, 2006
  • Jun 8, 2006
I thought that sounded like a Probst factoid.
Guess it's time for me to read that book again.
thanks dude
lead09
25
  • Jun 8, 2006
thanks dude
What book are we talking about?
vristang
4,933
101
124
Seattle
Jun 8, 2006
#10
  • Jun 8, 2006
  • #10
Ford Fuel Injection & Electronic Engine Controle - How to Understand, Service and Modify 1988-1993
By Charles O. Probst, SAE
A pretty decent book
If you care about the computer stuff
It can be found on Amazon and other sites
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Jun 8, 2006
#11
  • Jun 8, 2006
  • #11
Just MHO.
Good luck.
Trust me there is some small fluctuations ...put a voltmeter on it and check it and then get someone to fire up the car while you hold the voltmeter in place .......car off at .95 and then once fired up it will usually bounce between .97-.99
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
