Tps setting from .75 to .96ish
Dec 5, 2006
153
I got around to setting up my tps , it was at .75 then i went ahead and got it to around .96 and the computer finally learn its new setting , now when accelerating the rps hit hard then i take off 1 or 2 seconds after that. so basicly in 2nd gear im hitting around 4000 rps then it takes off 1 or 2 seconds after. now before that everything was hunkydory, any suggestions on what to do , im no expert when setting the tps but it seemed pretty easy and i used a pretty old unit when setting it , im gonna try to set it to where it was before and see if that solves the problem if it does not then im thinking either the clutch is slipping or somthing way outta my reach. Any suggestions of what else to do would be great as i miss the pull when i get on the gas pedal right away.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
attachment.php
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is less than $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
