- Dec 5, 2006
- 153
- 0
- 17
I got around to setting up my tps , it was at .75 then i went ahead and got it to around .96 and the computer finally learn its new setting , now when accelerating the rps hit hard then i take off 1 or 2 seconds after that. so basicly in 2nd gear im hitting around 4000 rps then it takes off 1 or 2 seconds after. now before that everything was hunkydory, any suggestions on what to do , im no expert when setting the tps but it seemed pretty easy and i used a pretty old unit when setting it , im gonna try to set it to where it was before and see if that solves the problem if it does not then im thinking either the clutch is slipping or somthing way outta my reach. Any suggestions of what else to do would be great as i miss the pull when i get on the gas pedal right away.
