tps
  • Thread starter Thread starter Mafia Mustang
  • Start date Start date Mar 26, 2007
M
Mafia Mustang
111
Arizona
Mar 26, 2007
  • Mar 26, 2007
Is there a certian way you need to set your tps on your car?
Would it cause the car not to start?
Should I be getting a power signal to the tps ?:SNSign:
bloopbloob
578
Alberta
Mar 26, 2007
  • Mar 26, 2007
dont know exactly what your doing but to set your tps turn your key forward but don't start it. pierce the green wire with a pin. take a digital voltmeter and touch the + to the pin, and the neg to a good ground. loosen the 2 screws on top, and turn your tps till you get to .985V.
i don't think a poorly set tps would cause your car not to start though...
HISSIN50
34
129
Mar 26, 2007
  • Mar 26, 2007
The TPS will zero out and if it cannot, it should throw a code.
In general, a TPS reading of 3.7+ volts can keep the car from starting.
Good luck.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Mar 26, 2007
  • Mar 26, 2007
Good luck.
Sorry to ThreadJack, but I just bought a new Ford Racing 65mm TB and it already comes with the TPS Installed, is it going to be preset or will I have to adjust it?
HISSIN50
34
129
Mar 27, 2007
  • Mar 27, 2007
E - what I would do (note that I said "I" in case S&2B's comes in here later ) is do the install and simply check where your TPS is baselined. It should be real close. Unless it was off by a country mile, I'd leave it myself (ratcheting keeps a reading within adaptive-control in spec).
It is nice to see where you're starting off though (I know you're a pretty particular/meticulous guy). A personal E.g.: I've never adjusted the one on the '88, but I know it sits at just under 1.20 volts; that's fine with me.
Just MHO. Good luck.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Mar 27, 2007
  • Mar 27, 2007
Thanks for the help, so if I am pretty close to 1 Volt, I am good to go then?
HISSIN50
34
129
Mar 27, 2007
  • Mar 27, 2007
You got it.
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Electrical Stumped No Start...
  • sydhawk
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
sydhawk
TPs sensors different?
  • Creomod
  • Sep 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2026
DadLife0724
