Trac Lock Rebuild?
xherdlr said:
Im replacing a worn axle and wheel bearing. Since I will have the differential cover off I wanted to rebuild the Posi unit. My question is.. Can you rebuild the unit without taking the ring and pinion out ?
Kelly
You can remove the carrier (which has the ring gear attached). The pinion gear does not have to come out.
Have fun. :nice:
nada, the ring gear is still there. Yoiu don't even take the dif out at all. I took me about 4 hours from start to finish, no lift, just a jack and jackstands, and a few common tools. Works goo,d wel worh the $40 or so i paid for the rebuild. nows the time to do it if you have to take the dif apart anyway. also you
ll have to take the axels out a little when rebuilding the trac lock, so you bsicly just gota put the new one in. :nice:
