Track heat heads and intake with e303 cam ?
The AntiRice
28
ok as some of you may know i got a bunch of performance goodies with my saleen clone when i bought it. all she has on her are the e303 cam, catless h pipe, axle back exhaust, ac delete, msd coil w/wires, new bosch platinum 2 plugs, and a new bbk fenderwell intake.
I wanna throw on the track heat heads, intake, and crane cams gold 1.6 roller rockers, that i got with the car but just wanted to know if it will be "ok" until i can do a bigger throttle body and long tubes. If so what mods and in what order should i add to that setup? will i have any valve clearance issues with those heads and an e303? any advice would be much appreciated.
*edit* also what gaskets will i need to get to do that swap and what rocker bolts as well? anything else i would need to get on top of gaskets?
I have pretty close to the same combo your going with and I've been very happy with it for the few weeks that I've had her on the road.
If you have no gaskets, summit racing sells a trick flow top end swap kit that comes with all the gaskets you'll need.
