I am planning to convert my 65 Vert from a C4 to a 91 Mustang AOD this winter. I want to add a trans cooler but not sure where to put it. Does someone want to tell me where to stick it?
The transmission people I talked with recommend running the fluid through the radiator before going to a cooler. The plan is to run the hard line to the radiator with a rubber line out of the radiator to the cooler and a hard line back to the AOD.
Where the sun don't shine!!!! Haha!
rsev216 said:Does having it in front of the radiator affect engine temp?
what he has in mind i think will be the wrong shape. he will probably want something more, shall we say rounded for your suggestion.![]()
That will work fine.The transmission people I talked with recommend running the fluid through the radiator before going to a cooler. The plan is to run the hard line to the radiator with a rubber line out of the radiator to the cooler and a hard line back to the AOD.
