  • SN95 4.6L Mustang Tech
tranny fluid capacity
  • Thread starter Thread starter ocbaud
  • Start date Start date Jan 12, 2006
ocbaud
239
Midwest City, Oklahoma
Jan 12, 2006
  • Jan 12, 2006
alright, i'm soon gonna be swapping my triax shifter for a much nicer mgw shifter and figure i might as well change the tranny fluid since the shifter will be off, since i'm not sure when it was done last, if ever. i've got a tr3650 btw
i work at a car dealership and have access to royal purple fluid at a discount. would this be a good fluid to use?
i'm guessing i need the Max ATF fluid??
how much should buy? 4 quarts? i'm not sure if the tsb has been performed on my tranny. when the car is cold it will grind going into second. and the first and only time i've taken it to the track, it would grind going into 2nd and 3rd on some runs.
thanks for all the help
squares98
852
Orange,ca
Jan 12, 2006
  • Jan 12, 2006
Redline makes great fluid for the tr3650/t-45's transmissions.
Doesnt the manual tell you how many quarts it takes, I'm almost postive its different than my t-45
ocbaud
239
Jan 12, 2006
  • Jan 12, 2006
i believe the manual states its 3.8 quarts, but some on here have posted about using more/less with it helping grinding problems
Give Me TP
936
Republic of Texas
Jan 12, 2006
  • Jan 12, 2006
If you have the Tremec 3650, use 3.0L (3.2 quarts). I used Dexron III.
W
white-04
145
Owings, MD
Jan 12, 2006
  • Jan 12, 2006
I shot for 3.2 quarts as well. I've seen people say 3.2-3.5. I didn't measure mine out to .2 quarts exactly, I just made sure I had between 3.2 and 3.5 in there. I used Royal Purple Synchromax.
ab 281 gt
123
Irmo, SC
Jan 12, 2006
  • Jan 12, 2006
What about a t-45?? i want to put some royal purple in sometime. Also w/ royal purple would I need the atf or the syncromax?
ocbaud
239
Jan 12, 2006
  • Jan 12, 2006
whats the difference in the max atf and the syncromax? we dont seem to carry the syncromax here and i can pick up the max atf for about $6 per bottle. is there a big difference in them?
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 4, 2026
JD1964
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
C
Progress Thread 2004 Comp Orange GT
  • ctandc
  • Jun 26, 2023
  • 2 3 4
5K
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
squeak93
N
Drivetrain 07 Mustang GT TR3650 3rd Gear
  • noahgt
  • May 25, 2021
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 25, 2021
noahgt
N
