Tranny Fluyid Change?
bobbys9350
472
Hey guys i got 3 quarts of royal purple synchromax tranny fluid. how many quarts will it take to change the fluid in the 05 gt? how do u go about doing it? just jack the car up and take out the drain plug then just fill it back up? and how far up do u fill it? sorry guys never done a fluid change in a manual tranny... THANKS A LOT! :SNSign:
These trannies take around 3.2 quarts. In your owners manual there is a section for this. I'm not sure about the synchromax, but I use Redline D4 ATF and the trans shifts very smooth. I think that the synchromax is okay for these trannies. I change mine every 15000 miles.
I've used it too and have it in the garage. It's a fact that regular dextron will give better high rpm shifts do to the need for some friction for proper syncronizer operation. The Syncromax will lubricate and protect the transmission internals better, but it's a trade off. If you have a flawlessly operating clutch system, the Syncromax is a good thing. If you have any trouble at all with high rpm shifting, dextron is the way to go. A lot of big time drag racers stick with the dextron. I'll be trying the Syncromax again now that I have a re-engineered clutch from Centerforce. Just showed up yesterday.
+1 Very true.
JTGrant said:
did they fix the problem you were having?
Yes, they sent me a re-engineered clutch package. It has less weights on the diaphram and the spacing is different. Just put it in today and it feels real nice. The clutch engages about 4" from the floor where the first one was at about 2''. I had the first gen package and ended up putting a .150 shim behind the throwout brg. That was pretty nice, but for speed shifting, the new one is better.
