  • 1994 - 1995 Specific Tech
Tranny help!
  • Thread starter Thread starter Synned
  • Start date Start date Feb 3, 2006
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Feb 3, 2006
  • Feb 3, 2006
Okay so I was driving the other day and decided to give it some gas. I floored it in first (Shift lever in D) and took it to about 5500 rpms and let up, but before it shifted, I gave it more gas. So it was like floored, stopped, floored again. Anyway it wouldnt shift out of first and made a weird bang noise.
Ever since then, sometimes my car makes this bang noise when upshifting or downshifting. It happens randomly.
Also, I have the dreaded torque converter shudder. Under light load the car tries to lock up the converter but the converter can't grab.
Does this sound like a converter issue or a tranny problem?
The only sound I can relate it to is when you are driving a manual and you are going wot and from first to second drop the clutch and you get that bang.
bill302
2,131
alabama,gadsden
Feb 4, 2006
  • Feb 4, 2006
my best advise is carry it to a few reputable tranny shops usually they will test drive and offer there expert opinion and an estimate free of charge. thats why i carry it to atleast 3 shops and compare notes i have done this in the past and usually you will get some good info. about what is wrong with tranny.
sage2k
645
Baton Rouge, LA
Feb 4, 2006
  • Feb 4, 2006
i dunno but i'd start saving asap for a new tranny, im in process of locating AODE to T5 swap parts myself
Yobi1Kanobi
559
  • Feb 4, 2006
aode is expensive to repair..just swap it.
Mustangless
903
home
Feb 4, 2006
  • Feb 4, 2006
have you checked your fluid?
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Feb 4, 2006
  • Feb 4, 2006
The shudder is for sure the conveter. The lock-up function is not working. You can have a chip burned to shut the lock up function off, so it won't even try to engage lock up. I had a 95 GT that did this to me. The chipped cured the problem. The trans shifted better too because they tune revamped all the shift points, firmness and rev limiters. With the lock up function shut off, the trans will run a little bit warmer, but you can always install a trans cooler. Lock up is also used to save a little bit of gasoline. The mileage won't suffer, because when lock up kicks in it is usually between 2 and 3rd gear and it only lowers RPM's by 200-300 RPMs.
R
reject5.0
153
Round Rock, TX
Feb 4, 2006
  • Feb 4, 2006
I dissagree. Its a very simple trans to rebuild. You can get one to handle 400+hp for well under 2g's
EDIT: doesn't PA automatic make an aode that handles 500hp for $1600?
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
R
Mustang mk6 v6 strange leak
  • reme24
  • Mar 18, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Mar 26, 2025
89ripper
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
