  • 1994 - 1995 Specific Tech
Tranny help!!
  • Thread starter Thread starter jmhkas
  • Start date Start date Jul 7, 2007
J
jmhkas
82
Bowling Green, KY
Jul 7, 2007
  • Jul 7, 2007
So I recieved the "correct" bellhousing yesterday in the mail. If some of you don't remember my story, I have to get a new tranny and bellhousing because mine went out like the 4th of july. Well, someone sold me a 99 v-6 tranny swearing it would bolt up and work the same. The tranny's are identical and the bellhousing mounts up nicely. Thing is when I reinstalled the starter, when you turn it over, it won't hit the flywheel. Someone told me that the bellhousing on the 94-95 was just a hair smaller in the starter region because of the difference in flywheels.
Now to today, ripped the old bellhousing out and reinstalled with the "correct" one. It's suppose to be off a 94 5.0. But yet I still get the same problem?? It just turns over, but won't hit the flywheel. Can anyone please help me out?? The flywheel is on the correct way also. I've had ppl ask me that one. Starter when turned over operates correctly. It turns and pushes that gear out. Anyone else had this problem? Anyone else install a 99 v-6 tranny in a 94 - 95 5.0???
Here is the ebay listing from the bellhousing I bought.
http://cgi.ebay.com/ebaymotors/ws/e...RK:MEWA:IT&viewitem=&item=150135322763&rd=1,1
J
jmhkas
82
Bowling Green, KY
Jul 7, 2007
  • Jul 7, 2007
Someone just now also suggested that maybe I recieved the wrong flywheel when I went and had it turned?? They said ford makes different size flywheels and that even if they are a different diameter, it would still bolt up. What are the chances of this?? Can anyone tell me the correct diameter I need. Do you measuse straight across from tooth to tooth or tooth to the shaft hole??
reddy351
560
12
38
Columbus, Ohio
Jul 7, 2007
  • Jul 7, 2007
You count the teeth on it. The 5.0's have 157 teeth and the 3.8's have 164 teeth. Someone prolly sold you another 3.8 bellhousing. I'd be pi$$ed. Especially if they sold to you it as a 5.0 bell. Ebay? SN Classifieds?
J
jmhkas
82
Bowling Green, KY
Jul 7, 2007
  • Jul 7, 2007
It was from ebay. The part number on the bellhousing is RF-F4Zr-6394-DA. If I'm not mistaking, the F4 means it was out of a 94?? I was thinking maybe the dude gave me the wrong flywheel when he got finished turning it??? What else could be wrong??
The OLD shattered bellhousing wore the same item number, but the last two ended with CA, not DA as the new one does.
The flywheel on the car now has the part number stamped. It is, RF-E1ZR6380-A2A.
SOMEONE please help me out with this.
J
jmhkas
82
Bowling Green, KY
Jul 7, 2007
  • Jul 7, 2007
Think I found the problem. I'm pretty sure I just got jipped...I put the old bellhousing back together to get the relative size of it and put it in the new bellhousing I recieved. The new bellhousing I recieved is larger than the old bellhousing. Also the old one does NOT have 5.0 stamped on it. Hopefully I can get something worked out here. Thanks all.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jul 7, 2007
  • Jul 7, 2007
pics of my old bellhousing if they help any. (shameless plug: its FS btw)
i can also measure the stock flywheel if u need that
J
jmhkas
82
Bowling Green, KY
Jul 7, 2007
  • Jul 7, 2007
Do you think someone bull****ted the new bullhousing?? Do you still have that bellhousing? If so are you willing to part ways with it?
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
J
88 Foxbody 5.0 Driveshaft Issue! Need Help
  • James Hood
  • May 1, 2025
Fox 5.0 Mustang Tech May 1, 2025
AeroCoupe
