tranny problems
  • Thread starter Thread starter slow93
  • Start date Start date Apr 10, 2006
slow93
406
  • Apr 10, 2006
a friend of mine just bought a 93 stang with a 2.3 and it has some tranny issues.he said it will go into all the forward gears but will not go into reverse.when in the foward gears it doesnt pull very hard though. he also said that it has a leak.any ideas on what could be wrong with it other than being low on tranny fluid.can it be fixed easy or is it time for a new tranny?
slow93
406
  • Apr 12, 2006
ttt
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Apr 12, 2006
  • Apr 12, 2006
it doesnt pull hard because its a 2.3l....just kidding. it could be a clutch issue. it wont go into reverse at all or its just hard to get into reverse.
FORCED2DV8
458
Grand Rapids MI
Apr 12, 2006
  • Apr 12, 2006
Is it a Auto or 5spd, Does it go into reverse at all?? If it leaks, then a seal is most likely the cause, unless it has been abused and the case is cracked.
If it is a 5 spd, then maybe the motor is tired, or if the trans has no fluid or has been ran low the bearings could cause drag. Try takeing it to a trans service center that does free estimates and see what they have to say.
slow93
406
  • Apr 12, 2006
it is an automatic, and he said that it wouldnt go into reverse at all and was real sluggish in foward gears, even more sluggish than a 2.3 is supposed to be..lol
Rynb15
132
Apr 12, 2006
  • Apr 12, 2006
when he gives it gas and its in gear does it just rev up and not go anywhere. Kind of like if you had the clutch pushed in half way on a 5spd car? My guess would deff be time for a new tranny.
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
P
Progress Thread New To Me 1988 GT - trying to set up vacuum lines for upper intake question
  • pindude80
  • May 6, 2025
  • 9 10 11
16K
Fox 5.0 Mustang Tech Mar 28, 2026
pindude80
P
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
