  • 1994 - 1995 Specific Tech
Tranny Questions
  • Thread starter Thread starter Wild95Stang
  • Start date Start date Apr 17, 2006
W
Wild95Stang
40
  • Apr 17, 2006
Alright so I see all of you guys that have Stroker motors and Blown 302's but what are you all concidering when it comes to transmissions. I'm looking at starting on a stroker motor this summer probably 331 or 347 less that 500hp. I know the SN95 came with a World Class T-5 but from my knowledge and reading the specs it can't handle what I'm about to throw at it. What are some options. Rebuilding it with stronger parts or going with a Tremec TKO (which requires longer driveshaft, different clutch fork, and cross member mods). Let me know what I can do. Thanks
W
Wild95Stang
40
  • Apr 17, 2006
so nobody knows anything about beefing up a tranny or fitting the tremec on a SN95?
95strokerPSU
986
Sacramento from Philly
Apr 17, 2006
  • Apr 17, 2006
I went with one of the last Tremec 3550s before they switched to the 500 and 600 transmissions. Here's a link to a recent thread about the 600, which is what I would recommend. http://forums.stangnet.com/showthread.php?t=625518
droptopford 5 0
427
Apr 17, 2006
  • Apr 17, 2006
if you don't want to deal with the different dimensions of the tremec, a g-force t-5 might be the way to go, however, many more guys opt for the tremec because it is proven to kick a$$ where there isnt much experience with the g-force trannys
W
Wild95Stang
40
  • Apr 18, 2006
alright so say I go with the Tremec? What mods am I expecting....different bellhousing?...different clutch fork?....some crossmember mods??
droptopford 5 0
427
Apr 18, 2006
  • Apr 18, 2006
i wish i could help ya with all fo the differences... i dont know myself, but ill say that its everything you just said, and maybe more. theres so many guys on here that can help you in that department, use a search on tremec swaps and tremec trans and i bet you'll find all the info you'll need if no one chimes in here
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Apr 18, 2006
  • Apr 18, 2006
Driveshaft spacer, shifter, 26spline clutch disc
SVTCobra306
170
Ft. Bragg, NC
Apr 18, 2006
  • Apr 18, 2006
The TKO500/600 comes with a shifter. Kinda notchy for my taste though.
Everything you may need:
Foxbody Clutch Fork
Tremec Bellhousing
New clutch for 26 spline (if you get the 600 or upgraded 500)
New Motorcraft T/O bearing if using a SPEC clutch (spec's throwout's are throwaways).
3 quarts of GM Syncromesh fluid
31-spline d/s yoke
3/8 driveshaft spacer kit w/longer bolts (steeda)
you may need to elongate the holes in the crossmember slightly to fit the shorter tranny. Some have had to flip the crossmember to solve vibration issues, some haven't.
a 1/4" spacer to go between the motor mount and crossmember, or a PHP crossmember adapter...
things recommended:
New front U-joint as you will have to pound the old one out.
If you don't already have an aluminum D/S, I'd recommend going with one for a newer car, the T-45 had a 31-spline output already IIRC, so you absolutely won't have U-joint or balance issues.
BTW I'd recommend going with the 600. I didn't, but I got an upgraded 500 with the 26-spline input shaft. A 600 would have been like 14 dollars more expensive, so I'm kicking myself there....
W
Wild95Stang
40
  • Apr 18, 2006
wow...your a life saver....alright so the TKO 600 has a 26 spline input and a 31 spline output....so I go with the driveshaft for the T-45.....ok i understand everything but the motor mounts? Do I need different ones or whats this spacer you said was between the motor mounts and the crossmember?
SVTCobra306
170
Ft. Bragg, NC
Apr 21, 2006
#10
  • Apr 21, 2006
  • #10
Oops, my bad. I meant tranny mount not motor mount....
Not to ad plug or anything, but I bought mine from CFM and the service was outstanding. It was pretty much a one-stop shopping center (already had a bell though) and they shipped everything free inside the tranny box, except the clutch which came straight from Spec.
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
For Sale 1995 Mustang GT Convertible FOR SALE
  • #16Stang
  • Jun 21, 2024
SN95 Mustangs For Sale (1994-04) Jun 21, 2024
#16Stang
Intended Headers and Trans, questions about fitment
  • from6to8
  • Aug 6, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 6, 2025
from6to8
