Tranny swap woes....
  • Thread starter Thread starter blindoboy87
  • Start date Start date Dec 4, 2006
blindoboy87
11
Dublin, OH
Dec 4, 2006
  • Dec 4, 2006
my old trans took a trip on me about a month ago and im in the middle of a swap and am having a bit of trouble with the bellhousing.... ive removed all of the bolts but it still wont come loose. on the sides of the housing it seems like theres a couple of pins still holding it in place??? im wondering if i have to punch those out, or if its even worth it since the clutch still felt fine to me before the old trans broke? btw the transmission is away from the bellhousing since i thought it would be easier to do in 2 pieces. HELP!!!
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Dec 4, 2006
  • Dec 4, 2006
get something in there to pry em apart
blindoboy87
11
Dublin, OH
Dec 4, 2006
  • Dec 4, 2006
wow.... ive already tried using a crowbar to do so
bill302
2,131
alabama,gadsden
Dec 4, 2006
  • Dec 4, 2006
did you remove the starter...there has to be a bolt holding it somewhere.....
blindoboy87
11
Dublin, OH
Dec 4, 2006
  • Dec 4, 2006
yea i did, i had a friend whos a fairly experienced mechanic take a look at it and hes even stumped
V
v8only
2,378
22
49
Dec 4, 2006
  • Dec 4, 2006
make sure the tranny is physically laying on the ground and not pulled away, otherwise the input shaft could still be putting weight on the clutch fork/ t/o bearing, and the bell.
as well, there are a total of ten bolts to remove to get the bell out.
1. the very two at the top of the bell
2. the ones in the middle of the bell on the left and right side
3. the lowest ones on the left and right side.
4. the two starter bolts
5. the two small bolts that bolt the blockplate to the bell on the very bottom of the bell.
that's it, that's all of them. the bell pins are mearly guiding pins, and don't have to be punched out. If all those bolts are removed, get a bigger prybar.
bill302
2,131
alabama,gadsden
Dec 4, 2006
  • Dec 4, 2006
count the bolts removed,have you have removed (6) approx 3 inch bolts as followed from top(2)and sides(4)of tranny. 2 starter bolts and 2 dust cover bolts form bottom of bellhousing?total of 10 bolts.
blindoboy87
11
Dublin, OH
Dec 4, 2006
  • Dec 4, 2006
still stuck... one last question, when installing the throwout bearing does the bearing side face the trans or the pressure plate?
V
v8only
2,378
22
49
Dec 4, 2006
  • Dec 4, 2006
pp
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
C
5r55s auto to TR3650 Manual swap 4.0 V6
  • Ceskz
  • Feb 24, 2025
  • 2005 - 2014 Specific V6 Tech
2K
2005 - 2014 Specific V6 Tech Mar 27, 2025
89ripper
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
