  • 1994 - 1995 Specific Tech
tranny swap ?
  • Thread starter Thread starter saleener94
  • Start date Start date Nov 27, 2007
saleener94
153
Compton,CA
Nov 27, 2007
  • Nov 27, 2007
I know hesitation is a part of having an automatic pcm after a 5-speed tranny swap. What about feeling slower than before? Is this also the result of not swapping out the auto pcm to a t4mo? Will the T4mo really wake up my stang? I need reassurance that the pcm is the only thing holding back power otherwise I will feel as if the swap was a complete waste. Thanx.
saleener94
153
Compton,CA
Nov 28, 2007
  • Nov 28, 2007
nobody?
9
95trippleblack
60
Chicago
Nov 28, 2007
  • Nov 28, 2007
Did you try an disconnect the speedo wire from the tail shaft? That helped me find out I needed a 5 speed computer or chip after doing my swap. I am telling you it will fix the problem until you get a chip or 5 speed computer
I know i said to try it in another thread but you don't seem to want to listen to someone who has done he swap already and also tunes their own car with tweecer. When I did my swap I didn't change the computer and when you got on it and when the auto would have shifted it fell on its face bad
Take a look other people say the same thing
http://www.corral.net/forums/showthread.php?t=929887
http://www.corral.net/forums/showthread.php?t=636903&highlight=computer
http://www.allfordmustangs.com/Detailed/25.shtml
Quote for the allfordmustangs article (he used a chip with auto functions off)
(Electronics and Wiring
There has been much debate about the AODE EEC processors not working when doing a T5 swap. On this swap we used the same U4P0 Aode processor but with one additional component: An EEC Tuner Board.
With the Tuner we were able to modify the EEC Program by making just 1 parameter change :
TRANS_LOAD_TYPE_SWITCH=0
The default of 6 is for an AODE tranny.
If you keep the stock program the engine will hesitate a bit when the EEC senses its time for an AODE shift.)
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Nov 28, 2007
  • Nov 28, 2007
MY tuner always says he can make any ECM work with any trans with a tune. I would suggest getting a tune. Hopefully your guy can do it. I have sold my tuner AT ECM's and he tunes them for stick cars....or vice versa.
P
punksable
  • Dec 26, 2007
i did the t5 swap with no problems at all, i bought a 5 speed computer and harness, put it all in and never looked back.
i think you may need a computer or take it to someone that can tune it for that computer, either way the money is about the same, proubly cheaper for the computer and harness, i paid about 150.00 for my computer and harness on ebay.
as for performance, night and day!!! i went from a 14.5 to a 14.1 in the 1/4, then i bumped the timing and air pressure down to 22psi and took all the crap out of the trunk, including tire and clliped of a 13.9.
the aode chews up about 25 to 30 hp over a 5 speed, plus you can dump the stick at a higher rpm at launch.
saleener94
153
Compton,CA
Dec 27, 2007
  • Dec 27, 2007
Its been a while since my swap. Still feels a lilltle slow especially 1st gear. peels out and everything but while normal driving, 1st gear sounds good , but car feels slow. I mentioned previously that I got codes 189 and 181 running lean so that might be the cause.
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
1987 Mustang GT Mass Air Conversion Help
  • mustangmike6996
  • Jan 1, 2025
Fox 5.0 Mustang Tech Feb 4, 2025
mustangmike6996
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
