• Community Forums
  • Regional Forums and Event Information
Trans ? 3550
  • Thread starter Thread starter LordMustangGT
  • Start date Start date Mar 18, 2007
LordMustangGT
118
Port Orchard, WA
Mar 18, 2007
  • Mar 18, 2007
I'm sending my WC t-5 back to the guy who I bought it from and getting a 3550. I should be able to use the same driveline right? I know I need a diff. bellhousing, if you got one let me know. The 3550 has a 10 spine input too if I remeber right so the king cobra clutch stays in. Do I need a diff. crossmember? Any info on this would be great.
Thanks,
Matt
LordMustangGT
118
Port Orchard, WA
Mar 18, 2007
  • Mar 18, 2007
ok so I just did some searching, maybe should of done that first. Looks like I can get a ford racing crossmember for about 60-70 bucks to bolt right in the fox for the 3550. Bellhousing is pretty straight forward, and my stock driveshaft should work, lol Looks like I got everything under control.
If I've missed anthing let me know, or if you got some used parts let me know.
Matt
M
MyFordsFly
151
Mar 18, 2007
  • Mar 18, 2007
You can actually modify your crossmember really easily. You just take out the rubber bushings (they are two piece and pop out really easy) and grind the welds holding the sleeves. This way the sleeves will move back and forth. Push the sleeves to the other end, throw a couple of tack welds on and replace the bushings. Nothing to it really and alot cheaper than $70
stock50LX
Curmudgeon
1,858
University Place, WA
Mar 18, 2007
  • Mar 18, 2007
Matt
You'll need a new shifter too. If you don't weld, you can still get your old crossmember to work with some grinding.
LordMustangGT
118
Port Orchard, WA
Mar 18, 2007
  • Mar 18, 2007
I'll try that out first then. I Got a Mig wired feed, so no problem there. I'll give it a shot.
The shifter thing I got covered to, thanks!
352Ford2
393
Seattle,WA
Mar 19, 2007
  • Mar 19, 2007
The driveline will work if it is a 3550 and not a 3550TKO, the TKO version has a higher spline count on the imput and output shaft.
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
H
1966 mustang starter and pulley troubles
  • Hotrods4ray
  • Sep 24, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
Realmongo
  • Community Forums
