*** I've already looked at the bolt thread sticky ***
So over the week end I installed the bellhousing and transmisison... I was missing one of my long bellhousing to block bolts, so had to by a new one 7/16x14..
I bought 2 of the smaller ones also to have i case I need them... which I did, the 4 bolts that hold the trans to the bell housing, 2 of the heads didn't look good, so I replaced them with these....
I have a poly trans mount to install, and I can't find the 2 bolts that bolt the mount to the trans... and I was looking at the bolt sticky, and now I'm confused... it says the (4) bolts that hold the trans to the bell housing are "Transmissions to Bellhousing ---12mm x 40mm X 1.75 pitch. Ford# N605935-S2" Well I used the 2 extra 7/16x14 bolts, and they went in and tightened just fine... so wth!!!! so now I'm confused by that...
and I tried the old trans to bell housing bolt in the bottom of the trans where the trans mount bolts to see if that was the same size, and that also seem to screw in just fine, but yet the sticky says they should be "1/2" X 13 X 1-1/2” long" I want to go out to homedepot and get 2 grade 8 bolts, but now I'm really confused on the right size...
