trans problem.. no 2nd gear!!??
:shrug: ok..this is wierd. my car cannot downshift into 2nd gear at all when cruiseing..no grinding.. just wont go in,,well it will if i muscle the heck out of it.
i can however down **** into it when im at 15mph or less or complete stop. but jumps out alot of times. 1 to 2 shift is fine.im stumped.. i added some fluid today and helped a little.. the fluid in there is all gray and runny.im gonna flush it then.
any idears? lol thanks matt. car has a steeda tri ax shifter on it.. i adjusted the stops too,.,,,
grannycar said:
great lol. it grinds into first any way..lol so it has to be done sooner or later..
so its internal then?
Yup, it's time. If you have the skills and a moderate set of hand tools (plus a hydraulic press, about 100 bucks), you can do the rebuild yourself. The rebuild kit is about $100-150, can't remember, and it's actually quite easy. It can get a little more expensive if any of the gears need replacing.
