TransGo Shiftkit
  • Thread starter Thread starter alex95621
  • Start date Start date Sep 15, 2004
A
alex95621
32
  • Sep 15, 2004
I drive an automatic 91 lx 5.0 convertible, all stock cept dumped 2 chamber flows and a K&N air filter, I want to get some basic mods, like a shift kit and underdrive pullies, I was wondering if anyone knows how much a shiftkit helps you. I was lookin at the TransGo one and they run about 100 bucks and seem t obe good, like how much can it shave off a 1/4 mile? thanks for the help, in advance.
giddyup306
3,041
Sep 15, 2004
  • Sep 15, 2004
I'd get gears before I get the shift kit.
blk92stangg
583
Hawaii
Sep 15, 2004
  • Sep 15, 2004
I would go with the kit first, only because it can lengthen the life of an AOD, assuming it's in good health now. It won't shave as much off the quarter as gears will, but with a burnt out tranny, how fast do you think you can push the Stang down the track? On the otherhand, if your aod is on its way out, you could consider a t5 conversion.
A
alex95621
32
  • Sep 15, 2004
t5
I want to convert it but i dont have 1500 to blow, I'm pretty broke actually heh
blk92stangg
583
Hawaii
Sep 15, 2004
  • Sep 15, 2004
Ah, well, I did mine for 1000 out here in Hawaii where the junk yard charge an arm and a leg, which included new clutch/flywheel/ 5.0 shifter. There are stories around here where some guys do the whole thing for under 300...check out this site to see what is involved. It will definetely not cost you 1500 if you do it right, and do the labor yourself. westcoastford t5 conversion
timewarped1972
642
mesa, az
Sep 16, 2004
  • Sep 16, 2004
when i did my shift kit i did some research and saw a couple articles where it shaved 2 10ths off the time.........and with how the stock one shifts i can see how it would, not alot but worth it.......if you go with gears though you may wanna go with 373's so that when you do swtich to a t-5 your not over geared.........
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
A
Resolved Fuel pressure high at 52 new FPR same thing
  • afjLX
  • Dec 28, 2024
  • 3 4 5
5K
Fox 5.0 Mustang Tech Jan 11, 2025
AeroCoupe
