Transmission Bump as gear is selected
Twisted
387
Hansen,CT
When I am shifting into gear I feel a bump as the trans engages the next gear. I have been told that the clutch cable might need adjustment. I have a MM fireway adjuster. Which direction should I turn this to fix this problem. Is the bump from the clutch not fully coming off of the flywheel, should I turn the adjuster outward?
