ppost Member Feb 11, 2020 29 3 13 Racine, Wisconsin May 23, 2020 #1 May 23, 2020 #1 On the universal Transmission cross member Where do you tac weld? I read the install instructions they say it needs to be tack welded. Pictures on the instructions are not to good.
M Monkeybutt2000 Mustang Master Aug 11, 2019 1,387 851 133 Lafayette,IN May 23, 2020 #2 May 23, 2020 #2 You tack weld the tubes to the crossmember itself.
90sickfox Wasn't a pretty sight...and I've got big hands SN Certified Technician Mar 2, 2015 6,948 5,824 213 May 24, 2020 #3 May 24, 2020 #3 A bunch of people don't tack weld them and are fine. Monkeybutt2000 has it correct. You would tack the tubes to the crossmember.
ppost Member Feb 11, 2020 29 3 13 Racine, Wisconsin May 24, 2020 #4 May 24, 2020 #4 90sickfox said: A bunch of people don't tack weld them and are fine. Monkeybutt2000 has it correct. You would tack the tubes to the crossmember. Click to expand... thanks every time I get under the car I fine something else. Need more stimulus money Reactions: General karthief
