- Jan 10, 2011
- 400
- 113
- 63
Is the T6 trans harness the same between 2.3 and 5.0? Specifically, 1993 model if it makes a difference.
Depends on the year. Early t-5s did not have the NSS plug on the top of the trans. Also, some non-WC t-5s also did not have it. I do not know what year ford started putting the NSS on the cars but I beleive 87+ cars all have it.
The trans has a small 1-foot pigtail from the NsS that connects to the main body trans harness.
This harness is year and transmission specific. AOD cars do not have the plug for the NSS in this harness. Only t-5 cars do.
The harness connects at the drivers side foot well, runs under the carpet to the trans tunnel and then through and out to the trans. On t-5 cars, there are three connections...NsS, vSS and the reverse harness (with neutral safety jumpered in it). Some early 86-88 cars without cruise control will lack the VSS harness partmof it.
AOD cars will only have the VSS and reverse harness plugs.
