Transmission problems
  • Thread starter Thread starter 88stang88
  • Start date Start date Apr 3, 2011
88stang88
5 Year Member
Apr 28, 2005
309
St. Louis,MO
Apr 3, 2011
  • Apr 3, 2011
Just got the car back up and running and a couple days ago it died while trying to leave the house and I smelled raw fuel so I popped the hood and noticed fuel everywhere. Pushed it in the garage and started looking at it and noticed my #1 injector was not seated properly in the fuel rail (not sure how it happened but was a easy fix). Car runs fine but now it is having transmission problems. If you leave it in Drive it act's like its in 1st gear and unless you really romp on it then it wont shift into 2nd. If you drop it down to 2nd then it shifts fine into 2nd. Wont shift into any other gears.
Is there anything in the engine compartment that could have gotten wet from fuel and caused a shifting issue?
sn-95matt5-0
170
  • Apr 4, 2011
disregard for miss information.
good luck on finding the problem
toyman
1,944
54
79
Vernon BC
Apr 4, 2011
  • Apr 4, 2011
There is nothing to connect the transmission to spraying gasoline as described. There is no vacuum line to the transmission. I would suspect a bad or sticking solenoid in the tranny. However, before taking it apart or going to a tranny place check and adjust the shift cable linkage.
88stang88
5 Year Member
Apr 28, 2005
309
St. Louis,MO
Apr 5, 2011
  • Apr 5, 2011
Tonight I drove it home from work (six blocks) and had it in Drive trying to see how it was acting...about half throttle it will shift into second but no drive or overdrive. Full throttle or barely any it will remain as it is still in first gear. If you put it down into second tho it shifts immediately into second tho.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
