Transmission Question & Check Engine Light
afast93stang
1,407
North Texas
This is a t-5 from an 89 GT, the 5.0 and mostly everything else was swapped into a 93 coupe by myself. The car runs great, all the lights work, etc... but im not able to pull codes and the check engine light is always on.
There is an extra connector that didnt have anything to hook up to when I put the 1993 engine harness on. The donor car is long gone. Everything else fell into place and connected correctly.
So the question is, what does this connector go to and is it the cause of me not being able to pull codes? 2 different garages couldnt pull the codes either (one dealing only in mustangs).
[Looking from the drivers side under the car looking upwards]
attachment.php
I think thats the nuetral gear switch (or something to that effect) and if it is i have heard that it will keep you from pulling codes. jrichker said something about it in a my comp wont throw codes thread the other day. no to be confused with my mycomp wont throw codes thread from the other day.
The neutral gear switch plugs into a connector on top of the T5.
On the attached drawing, it is the pigtail hanging off the top cover. Item #6 on the drawing.
attachment.php
So I finally had time this week to work on the stang, I wired the Neutral Saftey Switch to pins 30 and 46, since the wires ones coming off the NSS were both black I had to guess at it. I tried the wires both ways, nothing shorted out , the car started and ran fine, but I still have the check engine light and I still cant pull my codes. My car gets around 25mpg on the highway so I know things are running correct, I just want my check engine light to go off!:bang:
With the power off, measure the resistance between the computer test ground (black/white wire) on the self test connector and battery ground. You should see less than 1.5 ohms.
attachment.php
If that checks good, remove the passenger side kick panel and disconnect the computer connector. There is a 10 MM bolt that holds it in place. Measure the resistance between the STI computer self test connector (red/white wire) and pin 48 on the computer main connector.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine
The following is a view from the computer side of the computer connector.
I want to make sure im doing this right, use the black probe as a ground, and the red probe into the black/white wire and it should read less than 1.5.
If im doing this correctly then its reading higher than 1.5
If im doing this correctly then its reading higher than 1.5. What is my next step?
You get to either replace some wires or chase through the harness to find the bad connections. In rare cases, the computer is a fault.Do not replace the computer until you have completely checked the wiring. The computers are very reliable and seldom fail.
I regrounded the ground lead to the car body and was finally able to pull codes with a circuit tester. Dam that Code puller.... :uzi:
I pulled 2 codes, 22 and 67
22 is MAP (vacuum) or BARO signal out of range - MAP -Correct?
67 is Park/Neutral circuit fault - PNP Correct?
