Transmission Questions
  • Thread starter Thread starter Shadrack
  • Start date Start date Oct 3, 2005
Shadrack
95
  • Oct 3, 2005
What is the best shifter out there for the T-5? How is the Steeda Tri-Ax shifter?
Also, i'm thinking that my clutch is slipping at WOT, because the rpms flutter in the 1-2 shift, as well in the 2-3 shift. After the run, smoke comes up out of the shifter/dash area. However, it doesn't really smell like clutch, or smell like anything in particlar, but I suspect a slipping clutch? Since the clutch is slipping a little, does that mean that I need a new clutch already? Also, how can I adjust the clutch to enguage sooner (goes to the floor before enguaging)?
On a side note, what is the best transmission out there for these Fox's. I'm not in the market now, maybe in a couple of years. I've toggled about the idea of a T56 (out of a wrecked camaro/trans am), or a Tremec 5-speed when this tranny goes. I've been told plenty of times that a T-5 can't take much abuse. If I don't swap trannies, i've considered sending the T-5 off to get beefed up, is that usually a pretty good choice? And if so, how long do they "normally" last?
Sorry for so many questions, just checking my options.
darthcual
985
Arlington, TX
Oct 4, 2005
  • Oct 4, 2005
I've got the B & M short throw and its miles above and beyond stock. I think any of them pretty much are. T-5's can take more abuse than most think. As long as your not making ungodly HP their really is no need for anything stronger in my opinion. Good Luck
HISSIN50
34
129
Oct 4, 2005
  • Oct 4, 2005
If you have the stock quadrant/pawl, pull up on the pedal to adjust the clutch.
If not, use your FWA and/or the rod at the clutch fork (on the adjustable cable).
Good luck.
Shadrack
95
  • Oct 4, 2005
Thanks fella's. I will check into it and let you know how it goes.
V
v8only
2,378
22
49
Oct 4, 2005
  • Oct 4, 2005
the three most popular shifters seem to be the steeda tri ax, the pro 50 and the newer (crap forgot it's name, grw? the one with the offset handle) and this was in no particular order.
if you're getting visible smoke, but no clutch oder, it's possible you could have a leak dripping onto your exhaust. Check the trans fluid level, then check for leaks. Could be your front or rear trans seal spraying fluid onto your pipes.
HISSIN50
34
129
Oct 4, 2005
  • Oct 4, 2005
Mgw.
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
K
Severe Drivetrain Shaking
  • KeithM412
  • Jul 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 29, 2025
AeroCoupe
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Drivetrain Clutch cable?
  • flashback87
  • Jul 14, 2024
  • 2 3
4K
Fox 5.0 Mustang Tech Sep 29, 2024
