What is the best shifter out there for the T-5? How is the Steeda Tri-Ax shifter?
Also, i'm thinking that my clutch is slipping at WOT, because the rpms flutter in the 1-2 shift, as well in the 2-3 shift. After the run, smoke comes up out of the shifter/dash area. However, it doesn't really smell like clutch, or smell like anything in particlar, but I suspect a slipping clutch? Since the clutch is slipping a little, does that mean that I need a new clutch already? Also, how can I adjust the clutch to enguage sooner (goes to the floor before enguaging)?
On a side note, what is the best transmission out there for these Fox's. I'm not in the market now, maybe in a couple of years. I've toggled about the idea of a T56 (out of a wrecked camaro/trans am), or a Tremec 5-speed when this tranny goes. I've been told plenty of times that a T-5 can't take much abuse. If I don't swap trannies, i've considered sending the T-5 off to get beefed up, is that usually a pretty good choice? And if so, how long do they "normally" last?
Sorry for so many questions, just checking my options.
