- Oct 21, 2006
- 515
- 43
- 49
I have a 93 Gt Mustang that is street legal, but mostly used for drag racing. 1/2 hr to the the track each way, and some occasional street driving.
I currently have a T-5z manual trans and want to convert to an auto with an overdrive that I can manually shift at the track.
What is involved in the conversion from manual to auto?
I'm looking at Dynamic Transmissions in CT. , PA Performance, who's a good company out there?
Converter type and stall?
I'm at 345 horse power and there may be supercharger later on down the road.
Any help would be greatly appreciated!
Below is my current set-up
Thanks
1993 GT Mustang / Ford Racing GT-40 Crate Motor B-303 Cam / 24 lb. Injectors / Stock Ignition / MSD EFI Blaster Coil / Edelbrock 5.0 Upper and Lower Intake with BBK Phelonic Spacer / Professional Products 70mm Throttle Body / C&L C.A.I. w/76mm MAF / Stock Air Box w/K&N Panel Filter / Holley Adjustable Fuel Pressure Regulator / Electric Fan / BBK Underdrive Pulley's / A.C. Removed / BBK Short Headers / Flowmaster Exhaust / Tremec T-5Z / B&M Short Throw Shifter / Alum. Driveshaft / 4.30 Gears / Detroit Locker / Moser 31 Spline Axles/ Subframe Connectors / Line Lock / Driveshaft Loop / BMR Upper and Lower Control Arms / Lakewood Adjustable Drag Shocks/ Holley 190 lph Fuel Pump /
Thanks
