Ive had a tremec tr3550 in my 67 mustang for over a year now but i still dont like the angle this thing has got the motor sitting at. Originally I cut the tunnel and lifted the trans to the point that one of the fan blades was about 1/2 to 3/4 of an inch away from the lower radiator hose (thought this would be good but didnt like the way my air cleaner sat). Now I relize the car has a 19 inch fan where there should be a 17 inch fan. So I can jack the back of the trans until the fan gets close again. My main mistake :damnit: was not measuring from the centerline of the old c-4 output shaft to the bottom of the tunnel so I could have used this to put the tremecs shaft at the same distance from the tunnel so is there anyone out there who can help me out with some measurments like the trans tunnel to c/l of output shaft and if you have a 17 inch fan how far is it from your lower rad hose to one of the blades at its closest point. Any help is greatly appreciated
1967 mustang fastback
351w
750 holley
vic jr. intake 2inch spacer
afr heads
tremec 5spd
351w
750 holley
afr heads
tremec 5spd
