Tremec Bell Housing Options
Chris-90LX
Deflowered by a 40 year old divorcée
245
Central, MA.
I plan on installing a Tremec 3550 on my ’90 LX.
What are my options on a bell housing besides the Fords SROD or aftermarket scatter shields?
Will any of the earlier bells work with a Tremec?
Thanks in advance!
If you're considering a scattershield, try the FRPP or McCloud bells. They are the same and do not need to be dialed in like the Lakewood units. Good luck! FWIW, I use a scattershield. Back in the 70's I owned a 70 Z-28 and had a clutch let go on me. It came thru the floor on the passenger side. Could have easily been the drivers side. Have used one on every stick car since.
A regular tremec bellhousing is like $169. I run the mcleod scattershield though. Its bigger and more of a PITA to work around, but more piece of mind knowing your safer.
